I installed 4.10 gears in my trans am and was getting the vibration from the steel drive shaft.I bought a used ls1 aluminum drive shaft and put it in about 600 miles ago.The problem was solved.Well now the vibration has came back and its about as bad as it was before, 70-80 mph and when the rpms are around 4k-5k i feel a vibration from the driveshaft.I havent done anything different to the car , i have installed a centerforce clutch about 200 miles ago but the vibration was happening before i installed the clutch so i dont think its related.I havent got to get back under the car to check it out but if anyone has any ideas let me know.
Ls1 driveshaft upgrade vibration
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.Tags: None
Did you have the gears installed, or did you do them yourself?97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
tripple check to make sure non of your wheel weights have fallen off, Many shakes can be atributed to that, make sure you always get your wheels balanced at a place that has the "roadmaster" balancer machine, way better balance. I can give the full explination why but I dont want to type that much, if you want the particulars I can give them too you just ask. Ihad the same kind of problem and could swear up and down it was the driveshaft, but it turned out it was on wheel on the back.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Im hoping it is the u-joints.The ls1 shaft was used but when i installed it the u-joints felt good so maybe something has happened there.Me and a friend installed the gears.We had all the tools to do it,it turned out ok but i get some whine in 4th-6th.I dont think its in the gears because when i changed to the aluminum shaft the vibration went away.The problem seems to be worsening too so im hoping u-joints.The 4.10 gears are nice but have been a little trouble, im changing to 3.73 since i am supercharged, maybe that will slow the driveshaft down a little because with the 3.23 ratio i originally had never gave any problems or vibrations.Thanks for all the ideas,ill also ck the weights too on the wheels.Any more ideas will be appreciated,im tryin to fix it without havin to take it to someone if possible.
