Well, have my new master cylinder from Dal, came with a new reservoir which I did not expect. Anyway I know I have to get the master cylinder bench bled off of the car, after it is done would the shop just hand me a bled cylinder filled with fluid? Does the action of pumping the piston thing in there actually pump fluid into the cylinder and then seal back up without any air after bleeding? (ie - no air can get in until it is reinstalled and the brake pedal is pushed)
I ask because a shop told me by the time I got it home it would have air bubbles in it which I can see because it looks like the holes for the metal brake lines just lead right into the master but maybe I am wrong if it works as described above and seals up until the pedal is pushed again.
If someone can make this simple for me I would appreciate it, I would like to take it to a shop and pay like $20 to have it done properly, put it on my car and bleed my brakes after doing pads/rotors.
THANKS for any help, looking forward to doing this in sub freezing temps
