Just a little background info first. Full BMR adjustable rear suspension with Intrax 2" drop springs.....
After doing the drop, everything has been fine. I am more than pleased. Yesterday I actually had some play time with the car, performance was just great. I realized also that I had yet to fill the tank to more than half full. I went ahead and filled it up and the rear suspension due to the added weight, dropped a little more. No clearance issues or anything, but..... I took it out and gave it WOT and I felt a driveline vibration. I immediatly backed off and things were smooth. The vibration only occurs at WOT, is most noticeable in 1st gear and subsides somewhat as the rpms climb. Basically I could only feel it around 3K rpm in first, after that the vibration is barely noticeable.
Before I get the car up into the air and start measuring the pinion angle this weekend, does this sound like the drop has altered the pinion angle enough to cause a vibration?
I then set the angle to 4° down and WOW! what a difference. My car hooked very well even on the street after that. I still had good off turn grip but the only thing was that I had to re-learn to gas out of turns because even though we did not technically change the thrust angle, the car just wanted to go straight instead of turn.
Once I got used to that I liked it, but my primary focus was straight line acceleration in the first place.
No wonder. I set it for 2º down and no vibration. That was it. I still could use more bite though.
Even though I am anal about maintainance and care, the car is definately driven spiritedly out in these back country roads.
