I wrote a post a little earlier about my right turn signal not blinking and was recommended to check the front bulbs. I've checked all the bulbs and nothings out. Does anyone have any other suggestions?
turn signal
Usually if only one side stops blinking you have a bulb out. Even a daytime running light will cause the same thing. Any 1 bulb will cause the flash to cease. Some of them have a dual element bulb that when your lights are on, light with low intensity. Then when the turn signal or brakes are activated, the high intensity portion illuminates. Easy to miss.
I had a similar problem on my vette. The turn indicator on the left would not work. It drove me nuts. The lights worked and the bulps all looked visually good too.
Noticed some oxidation on the solder part (contact point), Cleaned it all up and it worked every once in a while. Ended up replacing the bulp and never had a problem since.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
