My bolts/studs look like they had some type of sealer on them, but the manual says nothing about using anything on them. Has anyone else used something on them? Like maybe some Permatex non hardening gasket sealer?
Intake manifold bolts
the sealer is a liquid teflon. you should use it. its not a thread lock or any thing like that, its just that some of the intake bolts are "wet bolts" and the tip is actually in the water passages. i guess you could use teflon tape if you wanted to, but i like the liquid better.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
Originally posted by azkknthe sealer is a liquid teflon. you should use it. its not a thread lock or any thing like that, its just that some of the intake bolts are "wet bolts" and the tip is actually in the water passages. i guess you could use teflon tape if you wanted to, but i like the liquid better.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
its still kills me that they only get 25 ft.lbs of torque. be sure and go back and retorque after the first hundred miles and cool down..
there are two kinds of teflon, one oil resistant that is typicaly yellow in color, and one white. i use the white, and i have never had a problem. the claim is that oil will break down the teflon, wich i have not had happen on the 4 LT-1's i have done, and the countless other motors.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
I got the ARP stuff and it is white & seems to work fine. My biggest surprise was when all the manifold bolts bottommed out in the AFR heads - had to go and shorten them all of a sudden. I told the AFR guys they should have included a note about that because it was a major pain to find out in the middle of the install.
Originally posted by Kevin - Blown 95 TAI got the ARP stuff and it is white & seems to work fine. My biggest surprise was when all the manifold bolts bottommed out in the AFR heads - had to go and shorten them all of a sudden. I told the AFR guys they should have included a note about that because it was a major pain to find out in the middle of the install.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
