Small oil drops
  • Small oil drops
    The other day i changed the oil in my Z. I noticed that the oil pan had a very small amount of oil on it. The oil sensor above the drain plug was a little loose so i tightened it. After changing the oil i let it run for about 6 min, put it back up and checked for leaks. No drops or anything seemed fine, wiped all the oil off before i changed it too. Then a week later i noticed two small drops on the bottom, but its not leaking onto the floor. Wondering if its coming from the intake manifold or maybe somewhere else. Thankyou
    mine does it too, its a common thing for LT1's to leak at the back of the intake manifold. If you look at the back of it you could prolly tell. Mine started to do it when i put synthetic in.
    My Car
    Hooker 3" Catback Exhaust w/ gutted cat
    1LE intake elbow, K&N Filter
    Chris
