Hello i am new to this forum and was wondering if anyone could help me out. I have a problem with my 89 Firebird TA. At low revs, below 2000, there is a quite violent shaking when you try to accelerate, if the car is just coasting the shaking stops and once you get above 2000 revs the shaking stops. Along with the shaking the power is intermitant. Does anyone have any idea what this might be? any ideas would be appreciated
Problem with 89 TA
mikedTags: None
A description of the engine combo ie: tuned port or throttle body 305, 350 would help, but here's a start. When dealing with a stumble, first look for ignition problems. How fresh are the spark plugs, wires and distributer parts? If all of those are fresh, you could have a bad throttle position sensor, injector(s) O2 sensor and the list goes on and on. Start with those and if you don't find it, follow up with a post on what you've gone through.
Is the check engine light on? Is the problem intermittent or is it a regular miss. Sounds like bad spark plugs or wires or distributor. All of that just went south on me 3 weeks ago. After replacing it the car ran like a dream (then VATS system went out one piece at a time). It felt like i was down a coupla cylinders.
