I just had the antifreeze changed on the SS. I debated on doing it myself but I really have no good way of recycling the old anti-freeze. Besides that I couldn't find the drain plugs on the LS1 block that they tell you to open to drain the block (the shop manual tells you to do this but doesn't even give you an illustration showing you where they are located). I looked high and low for these things and if they are there I am either blind (a definite possibility) or they are just hidden from view. The radiator drain outlet was no problem to locate.
Anyways back to the subject. I watched the technician do the job at my local Chevrolet dealer and I question whether these machines they use really get all the old antifreeze out. If you have never seen one in operation, here is how they do it. They remove the radiator hose from the drivers side of the radiator located half way down the tank.....which automatically drains half the radiator into a tub they place under the car. Then they attach fittings and hoses from their machine to the radiator opening that the hose had been attached to and to the car's radiator hose that's been removed. Then they mix 2 gallons of antifreeze and two gallons of water and placed it into the inlet tank on their machine. (BTW........the cooling sytem capacity is 15.3 quarts or almost equivalent to the 4 gallons they have mixed.) There is also a recovery tank on the machine to collect the old antifreeze. Then they start the car letting the cars water pump do all the work of supposedly sucking in the fresh coolant while the old stuff is alledgedly going out to the recovery tank. As the engine runs the "theory" is that the water pump will pump all the old fluid out replacing it with the new. My theory says that no matter how hard you try you are still mixing the new with some of the old and therefore it doesn't get it all replaced with fresh stuff. I know every shop uses the same basic machine and method to change antifreeze these days but I just don't think it does a good job.
Anyone else have any thoughts on what kind of a job they think these machines do?
BTW......my old DexCool still looked good. I had heard so many horror stories about this stuff, I didn't know what to expect. It has been in the car for over four years now.
