biggest tire on a 18x9.5 wheels????
  • biggest tire on a 18x9.5 wheels????
    whats the biggest tire i can fit on a 18x9.5 wheel???
    thanks,
    ed
    Most manufacturers recommend no larger than a 285/35-18 on an 18x9.5" wide wheel (recommended range 9.5 - 11.0"). Next size up is a 295/35-18, and that requires a 10" wide wheel.
      injuneer,
      will the 18x9.5 with 285/35r18 affect performance in a negative way compared to my 275/40r17's ???
      ed
        With the larger wheel, you're moving the center of mass toward the outside diameter of the wheel/tire combo, and that increases the energy needed to bring the wheel/tire mass up to rotating speed. Small loss of rear wheel HP, a little more resistance to acceleration from the front wheels. Probably hard to measure. The thinner/stiffer sidewall will probably reduce straight line traction slightly as well. Again, these changes are hard to quantify.
        The speedo error will be less than 1%.
