Im thinking about buying a turbo, now i did have a powerdyne SC and i loved it but it was too much of a hassel when it came to motor maintance, and i dont have the time anymore due to the fact im in the Army, So i was looking into the STSturbo and i was wondering what should i do with my stock heads??(replace the internals to better ones??) , and what type of cam should i put in it??, i have 75K on the motor so i dont really want to rebuild the motor unless it blows
, how much boost could i run on the LT1 safely
but i want the car to move, Now through STSturbo i can run 7lbs of boost with their setup, could i go as far as 9lbs but with their methonal kit and of course PCM tunning ???....thanks
The difference is that motor is built to take that kind of boost. Do that with a stock GN engine and it's literally blown apart much like what would happen to an stock LT-1 (don't ask me how I know) , just with less boost. The bearing clearances are different, the rings are different, rotating assembly is all forged, 0-ringed deck/heads, block girdle, etc.
)and ill put a ________???? please help fill in the blank! The rear i dont know i have an Auburn rear with new bearing and superior axles, girdles, so i guess it should hold with the stock 10bolt cast
) but im shipping out for about 6months but ill leave any exposed parts covered and taped to minimize any futher rust, oh what about my damn brakes, rotors, calipers, what should i do about them??...i never let my car sit for more than 4weeks without starting or driving. any suggestions?
