[FONT=Arial Narrow][SIZE=4][COLOR=Indigo] 1994 camaro, V6. Cooling fan will not come on. Changed the engine coolant temperature sender, and the relay. wired it directly to the battery to make sure the fan was any good, and it works. what else could it be, is there a fan switch, and if so........where?
fan problem
kari2krazyTags: None
Are you sure you replaced the correct temp sensor? The V8's have seperate senders for the gauge and the PCM. I would assume the V6's are similar. There are fuses in the system.... did you check those?Fred
