Ive been hearing alot about this sts turbo and Ive been to there website and it looks like Gods gift to the f-body. Does anyone have any experence with this type of turbo or know anything about it? Im tearing down my motor and was going to go forced induction and these are the 2 names that keep coming to up. This turbo seems to be putting up some inpressive #'s. Pro's, Con's?
sts turbo or ati procharger???????
the only real con i can see is the length of the intake tubing, its just screaming turbo lag. on the other hand it will make more hp per pound of boost since there is no belt like on a S/C. so no paracitic loss.Originally posted by thomasIve been hearing alot about this sts turbo and Ive been to there website and it looks like Gods gift to the f-body. Does anyone have any experence with this type of turbo or know anything about it? Im tearing down my motor and was going to go forced induction and these are the 2 names that keep coming to up. This turbo seems to be putting up some inpressive #'s. Pro's, Con's?2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
Due to the fact that it has no intercooler and the pipe has aprox. that same volume as a intercooler the lag is nil, or at worst same as someone would find in an intercooled car. Plus the pipe acts as an intercooler droping an average 20 deg off the temp at the turbo or so I read in a carcraft mag.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
I bet one could build a small intercooler box for under the car that would scoop air from under the car and force it over the intercooler, or adding fins to the pipe would increase heat disappation. The only problem I see with this kit is the loss in velocity of exhaust due to the length of pipe before the turbo. But if one were to jet hot the whole pipe it may help to keep temps up before the turbo.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
or just put a Co2 sprayer along the pipe along the under side of the bodyOriginally posted by DeWynterI bet one could build a small intercooler box for under the car that would scoop air from under the car and force it over the intercooler, or adding fins to the pipe would increase heat disappation. The only problem I see with this kit is the loss in velocity of exhaust due to the length of pipe before the turbo. But if one were to jet hot the whole pipe it may help to keep temps up before the turbo.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
There putting up some pretty good #'s and the price doesnt seem too bad. I think its a couple hundred $ cheaper than a procharger. Does anyone have a procharger and like or not like it?
current
It definitely looks unique...One thing that bothered me was the location of the intake filter. It looks like it's sitting there in the open not far behind the rear wheel. Is this meant as a roadworthy upgrade or is it for track only. If it is roadworthy how do they protect the filter from all the dirt and junk on the road?Joe K.
'11 BMW 328i
'10 Matrix S AWD
It has a filter plus a special sock that is water resistant (gortex like?). I can see that one would probably have to change it more often, especialy if one is driving any kind of dusty roads, as the front wheels will kick up more dust for it to suck in.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
