Guys my Flexplate has had it..How difficult would it be to change it out. Will I need to yank out the Tranny completely or do I just have to back it out? Any help would be great. I would rather take this challenge than pay someone if it is not that difficult.
Changing my flywheel?
1badltlTags: None
Why do you think you need a new flywheel?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
1badltl
I have a 94 TA and I first notice I was having a rattling noise coming from the tranny. I removed the pan that covers the converter. With a flashlight I can see that the all five bolts that hold the flexplate in place have accutally dug into the flexplate itself (Sort of made slots for the bolts) I can jiggle the flywheel with my bare hands. Any help?
Originally posted by 1badltlI have a 94 TA and I first notice I was having a rattling noise coming from the tranny. I removed the pan that covers the converter. With a flashlight I can see that the all five bolts that hold the flywheel in place have accutally dug into the flywheel itself (Sort of made slots for the bolts) I can jiggle the flywheel with my bare hands. Any help?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
1badltl
Originally posted by 1badltlSorry Jeff 95 Yes I meant to type 3 bolts. I do have a automatic 4L60E.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
1badltl
Sweet I love this Forum I learn so much from people like you thanks.
Flexplate I need to change my Flexplate anyone have any info and difficulty level on changing this?
Originally posted by 1badltlSweet I love this Forum I learn so much from people like you thanks.
It might be possible to lower the transmission and slide it back on a tranny jack instead of completely removing it.
Dont let it scare you. It's really not that hard a job to pull a transmission. Theres the driveshaft, torque arm & crossmember. A few plugs, a linkage, two coolant lines and then the 6 housing bolts into the motor. If you allow the tail of the tranny to drop down low, you can use a 3 foot long extension to get the 6 housing bolts without smashing you knuckles up.Tracy
Originally posted by RocKin1967my flywheel has a hot spot on it and the fly has about 48k on it should i replace it or would it be fine to resurface it? how much does a stock flywheel cost for an ls1 6spd?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
A friend of mine is a GM truck tech and he showed me a trick and we were able to swap the flexplate on my Dad's old caprice by just slidding the tranny back and using a long wrench. We didn't even disconnect the tranny lines. I wasfor something to break, but it didn't. I don't think you'll have enough room on a F-body to slide it back enough. Not that bad of a job. Just get a 3ft extention and a swivel socket for the top tranny bolts.
Good Luck..2005 GTO (mine) K&N CAI and Magnaflow exhaust, drilled and slotted rotors, and other minor mods.
2002 V6 Firebird (wifes)
2013 GMC Sierra (mine)
2011 Cadillac CTS4 (wifes)
Originally posted by Jeff 95 Z28OH my. After what I went through resurfacing it, I would get a new one. You can get a stock one from www.gmpartsdirect.com for $173.85 for a 94-97. For some reason the part numbers for a 98-00 part # 12562765 and 01-02 part # 12570281 are coming up not found. I would NOT recommend a Centerforce flywheel. I have to take mine out this afternoon to get it rebalanced. Read this http://www.centerforce.com/faqmain.tpl#10000007 . They used a Blanchard grinder on my stock flywheel which caused it to have excessive chatter.1967 Camaro "Project"
1972 Chevelle "454"
1979 Trans Am "Project Ls-1"
