I just recently took ownership of a 95 Z without T's, 116,000, A4, bone stock. Naturally I want to go through and change all of the fluids oil, tranny, rear end. I'm not going to ask what kind of engine oil to go with, i've already put way to much thought into that subject. In fact I've decieded on the new Valvoline Synthetic for High Mileage in 5w30. But I have some questions on some of the other areas. Assuming that this 4l60e has never seen synthetic tranny fluid, does adding syn to a higher milage tranny cause problems? And what is the best tranny fluid? As far as the filter, I cant seem to find an improved aftermarket filter, only fram, wix, etc.. I assume this will work. Would it be wise to change the tranny pan to a aftermarket type with drain plug for future fluid changes? Also I've heard that the flush you can get done at the quick change type place is actually better because it gets all of the fluid evac'd, is this true? And just two more quick questions, does anyone make a improved fuel filter without going to something that uses different connectors and what fluid would be best in the rear end? Thank you for any advice anyone offers.
Jeremy
Jeremy
