My friend is about to get an 85 Buick with a 350. He has an 84 Firebird and he wants to do a swap. Does anyone have any experience with something similar to this? Help would be appreciated.
350 engine swap on an 84 Firebird
unorthodoxenderTags: None
You didnt include enough details on your post.
What kind of Firebird? V6? V8? Automatic? Manual?
What kind of engine is in the Buick? I assume it is a Chevy 350. I didnt think they put a 350 in any cars in 1985. Are you sure it is a 350? How do you know? A 305 looks exactly the same as a 350.Tracy
unorthodoxender
it's an 84 Firebird V-6 Auto. All I can tell from the Buick is that is is a Chevy V-8. The guy who is selling it says that it is a 350. I'm taking his word on it. But how hard is it going to be to do an engine tranny swap? The 6 in the 'bird is about to go anyway so even a 305 would be an upgrade no?
It's not worth it. I've done it, trust me. I once converted my 86 2.8 V6 camaro to V8. It is the only project I ever wished I hadn't done. I cost me a fortune! I should of just sold it and bought a V8 car, which is what I ended up doing anyways after I completed the car.Originally posted by unorthodoxenderit's an 84 Firebird V-6 Auto. All I can tell from the Buick is that is is a Chevy V-8. The guy who is selling it says that it is a 350. I'm taking his word on it. But how hard is it going to be to do an engine tranny swap? The 6 in the 'bird is about to go anyway so even a 305 would be an upgrade no?
you will need the following:
Engine - complete and running with belts, pulleys and accessories
transmission - preferably a TH700r4 /overdrive
TV cable and throttle/TV cable bracket
engine mounts
radiator and hoses
modified transmission crossmember
exhaust manifolds / headers and y-pipe
front springs for the V8 (the V6 springs are weak and the nose will sag enough under the weight of the V8 that it will bottom out everywhere)
carb & distributor (I assume the pair on there now are computer controlled)
possibly a fuel pump?
power steering pump hoses
aircleaner assembly?
entire gauge pod for the dash (the V6 tachometer won't work)
oil pressure sender (the V8 gauges have a 60LB gauge, and the V6 sender is for a 80LB gauge)
Bottom line: If you are going to go through the pain and expense of the swap, you'd better make sure that "350" engine is worth it. It better be a pretty special motor. Also, you'll want to replace the entire rear differential, because the V6 cars never got positraction. You'll also want to replace the catback with a high-flow model. I just cannot see how it would be worth it unless the car was in *mint* condition and the "350" motor was a monster. Be prepared for an expensive project, undoubtdly more than the car is worth.
Why not sell it and buy a V8 3rd gen firebird?? they are a dime-a-dozen? You can find 5.7 TPI cars for under $3,000. The V8 cars got closer ratio steering, better suspension and limited slip. I'd just go buy one if that is what you want.Tracy
