I have a 96 Ta automatic and it seems to make a noise on medium downshift and acceleration. It sounds like it is from the tranny, never slips and seems to do it in cold weather. Maybe a solenoid?
Downshift Noise
hoppy24Tags: None
hoppy24 -
An automatic should have no vibration in the shifter, it is bolted to the floor. It is cable operated and is remote from the transmission. If you are feeling a vibration, check to see if the rear trans mount is seperating. It is common for these to break and when it does, allows the tail of the trans to move up and down. It would be most noticeable in moderate engine braking or acceleration. If you find it is toast, get the more solid 1LE mount and it won't happen again.
BlueSteel
Rapid thumping noise
Joe my Z28 is experiencing the same distinctive noise which, is felt directly under the right arm console. When trans mount is checked what other problems or repairs might arise, if mount needs replacing where do I find a Solid 1LE mount if it's not a stocked part at AAMCO beep beep.
FYI: This link is invalid http://cv6.fakeleg.com/
If you don't fix the mount soon, you may damage the universal joints with the added change in driveline angle. other than that, there isn't much to it.Originally posted by BlueSteelJoe my Z28 is experiencing the same distinctive noise which, is felt directly under the right arm console. When trans mount is checked what other problems or repairs might arise, if mount needs replacing where do I find a Solid 1LE mount if it's not a stocked part at AAMCO beep beep.
Best GM prices are from:
Jason Cromer: 877-726-8295 or 850-243-8826 (direct parts dept ph #)
email: parts@samtaylor.com
Sam Taylor Buick/Cadillac Ft. Walton Beach, FL
or
Dal Slabaugh: 877-448-5451
email: lockitup@bright.net
VanDevere Buick/Pontiac/Olds Akron, OH
When I went looking for a 1LE mount, I couldn't find one.Originally posted by BlueSteelJoe my Z28 is experiencing the same distinctive noise which, is felt directly under the right arm console. When trans mount is checked what other problems or repairs might arise, if mount needs replacing where do I find a Solid 1LE mount if it's not a stocked part at AAMCO beep beep.
I ended up getting one from a Caprice Classic police car. I don't remember the part number. I need to take a picture of it. When I went to the 6 speed, I replaced it with an Energy Suspension mount because of an unrelated problem.
http://www.lmperformance.com/3118/2.html
I tried the Prothane and it was too noisy with the automatic.
To be fair I never tried the ES mount with the automatic. It may be that the automatic is why it was louder rather than the Prothane mount.
Note: From Shoebox's web site http://shbox.com/1/Parts.htm
1993-1997 transmission mount (now one number for all, including 1LE)
note: seems to be made like the stock
mount and not the old 1LE 22201140 $30.00
1998-2002 transmission mount 22174970 $41.21
1998-2002 transmission mount nut 10406946 $0.91
I'm 99% sure a 98-02 mount will work on a 93-97.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
When I switched from my stock trans mount to a 1LE trans mount after my A4 - M6 conversion, the difference was night and day. With my stock trans mount, my car would shake vibrantly when ever I would floor it or switch gears. That all got eliminated when I upgraded to the 1LE trans mount.Hercules
2008 Sunburst Metallic HHR LT
