my abs inop light has started to flas as i am driving mainly when it is damp bot it does do it when it is dry as well it is a stedy flash and not intermitant it did come on befor and stay on so is the flashing somthing different?
i had that problem for a little while too. Just get into the fuse box (under the hood) and see if you can clean off the abs fuse. Sometimes its just a bad connection... mine stopped after that.
Since you mentioned that it does it when damp, check the sensor(s) harness connections at each front wheel hub and on the singe one top of the rear differential. Pull the wetherpack harness connections, clean them with electrical contact cleaner and re-install. If there was any water intrusion, that should cure it.
