Please can someone tell me where the other bolt is that holds the headlight assembly in the car? i found the two on the top .. is there one behid the headlight? on the bottom? i am removing this to fix the headlight motor.. that you
please help.. please Headlight removal info??
87PontTATags: None
Try this website. Brent Franker has a video (MPG) file that you can down load that helps alot (it's for post '98 models).
http://www.bfranker.badz28.com/headl...x.htm#Ordering
Good luck... and remember to align the headlight lift arm with the gear before epoxying the plastic gear box together.
1999 Black TA Ram Air M6 with lots of Mods and many coats of Zaino!
http://community.webshots.com/user/runbikejrb1
