Brazing is rather easy but hot. If it were me I would just tap a hole and put a fitting in it so that you can thread the probe into the fitting and be done. Either way you will have to take the pan off, and if you haven’t ever brazed and don’t have the equipment (acetylene torch, brazing rod, face shield etc.) its easier to just drill a hole tap it and add a fitting then thread in the probe and be done. Just make sure you use some kind of tread sealer.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
I'm pretty sure there is a plugged hole on the 4L60E that can be used for the temp sensor. No need to weld it into the pan. Check Shoebox.... he may have a picture of the plugged hole on his Tech Pages website.
I actually got an autometer trans temp gauge put in my car about a month and a half ago. Being that i have no experience installing gauges, i didn't want to accidentally screw anything up on my car, so i had it done profesionally. I know for a fact that they didn't have to weld anything to put it in.
You can buy an adapter. My autometer water temp gauge came with the sensor and a few different fittings to make it universal. I rec. putting it in a stock bung. I wouldn't drill into the intake and tap it, that would make for possible future leaks.
I'd get a "T" fitting and put it inline to the radiator. If you put it in the port on the side of the transmission, you might not get a flow of fluid across it. If you don't, you'll only get a local temperture.
He has a trans temp gauge, not water. I was using water temp gauge as an example. Unless you meant to say tie into the radiator?
