I'm kicking around the idea of building a 383 for my car in a couple years. I'd like to start building knowlege about it and ahve some questions that I have not been able to get answered using the <SEARCH> feature.
1) Balancing... Can I use my stock flywheel and balancer? Is my stock motor internally or externally balanced? I've heard people talk about a "balancing plate", what is that exactly?
2) Cam.... Everyone talks about a cc306 cam. Is this a Comp Cams grind? What is the exact part number? Is this a good choice for a street driven car? Will it totally destroy my fuel economy? Is this a good cam to use on a M6 car?
3) Rotating Assembly.... My car is street driven. It would rarely if *ever* see track use. Do I really need forged internals and a 4-bolt main block? Would cast be good enough?
4) Heads.... should I have the stock ones P&P, or buy different ones? What is the performance / cost difference between the two? What are your suggestions?
5) Drivetrain... Would this setup in my M6 car destroy the rearend on street tires? Would my SLP clutch be enough to hold it?
What kinda headers are you planning to go with?
