rear-end question
  • rear-end question
    I was wondering if this was normal, I notice it when I'm leaving work. when I drive off and turn out of my parking space it feels like my rear is hoppin. does the posi make it feel that way. Thanks for any info.
    1987 Monte Carlo SS, Lightning rod equipped. edelbrock intake/carb, heddman headers, moog suspension, dual snorkle air cleaner, no comp/emissions. Body off restoration.
    http://www.cardomain.com/ride/2167110
    if it is a slow very tight turn, then yes a posi can and will do this. its probably working fine
    past rides:
    1994 Z28 A4 totaled
      Its chattering. You should either change the fluid or add the limited slip additive. Its not going to hurt anything the way it is. Just bothersome to most. That's why the additive is added, it allows it to slip so it doesn't chatter.
      Rob
      04 GTO
        yes its slow tight turn, I have a new posi, fluid and the additive was added.
          its most likely your tires and its normal, seeing as the posi is brand new.
          past rides:
          1994 Z28 A4 totaled
