im going to try an msd wiring harness for my ignition retard box. the msd part number for the harness is 8876. msd's site says that autozone doesnt carry it. has anyone ever tried one of these harnesses and how much do they generally run. i think this would be my best bet because my msd boxes usually fry when im sitting in traffic so if i could simply just plug the stock ignition back into the coil after the box failed, i would be golden. i was origionally going to try to just put in a few relays and switches and do alot of slicing but i think this msd harness is a much better bet. also my msd box(es) keep frying i tried mounting it in the pass side kick panel with a 3/16 hose from the manifold to it but it was running way too rich. i think its the length of the hose i ran about 6 feet of hose from the manifold then i turned it over and it was runnning real rich. im thinking if i just mount it in the motor compartment where it origionally was but with some sort of heat shield. or maybe i might just need a thicker hose running from the map to the msd box. anyone ever had this problem before with the 6BTM box? thanks!
-chris
-chris
