I am trying to install a boost gauge on my trans am.Where is the best place to put it to install the fitting.I cannot find any ports on the engine to use but im sure i am missing something.The gauge came with an install kit, i have a couple brass bushing to thread into the engine but i cant find where they go.
Installing boost gauge??
95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.Tags: None
Use a vacuum T and tie it into one of the vac ports on the intake. Not sure if there is an exact one, but that's usually the standard procedure.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
maybe one of the nipples on the TB if there is one.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Use one of the ports on either the passenger side of the intake manifold (fuel pressure regulator, HVAC controls) or on the drivers side (Opti vent, EGR vacuum). Just "tee" into it with a plastic fitting.
I would avoid the "ports" on the throttle body - the top one is not vacuum, its the air supply line from in front of the blades to the passenger side valve cover/PCV system. The lower one is for the EEC purge vacuum,, and I'm not sure it is a "full vacuum" port.
Shoebox has photos of the locations of all the vacuum ports.
Driver's side:
For the paasenger side, you can see where the FPR vacuum line connects in this shot, and the nipple for the HVAC control vacuum source is right above it.
