Is the 700R4 Transmission the only one that came behind the V8s in 82-92 camaros/Firebirds? I want to put a 350 and TH350 tranny in my 86 and someone told me you have to use the tailshaft from an 82-92 firebirds 350 tranny. As far as ive seen they didnt come with TH350s
Tranny/Engine Question
86BirdTags: None
The earlier ones may have come with a 350 (82-83) if they werent 200's. You could have your shaft elongated at any driveshaft place though - just take the measurements96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
