That is identical to my setup. I have six small switches in the ashtray to run the e cutout, both fans, fuel pump, and antenna defeat. The fuel pump and the fans are all relay controlled, so you are switching an amp or so to run (ground) the relay coil. The e cutout is a couple amps to run the motor. I use 16 ga wire to the fan relays in the fusebox, and 14 back to the e cutout & fuel pump relay. The switches are rated at 6A/125V adn 3A/250V which is about 750W which is plenty for a small DC load. Ideally, you would to go by a DC rating of the contacts and the current draw of the load you are switching, but you mostly see that rating on relay contacts. I used these switches for about 6 years now, and they are A-OK. Also, I have about 2 feet of leads coming off the switches to a connector under the dash which makes it easy to disconnect and remove the switch panel and console. You'll be sorry if you hard wire it in with short wire.
Your switches are a bit higher rated than mine, but since you've had no problems in several years, I feel much safer now.
