Is there any special procedure that needs to be followed when reconnecting my PCM?
Reconnecting PCM
Just plug it back in. I'd recommend disconnecting the negative battery terminal first, just to be on the safe side.Tracy
yes.
plug the terminals back in.
carefully insert the pcm back into its "slot"
bolt it down.
walk to drivers door.
place key in ignition if not there already.
turn key until starter engages.
let go of key when motor fires.
drive it like you stole it set pcm parameters........
bwwaahahahahahaha
i crack my selfup.......
