NFB- can you determine gear ratio on 96 S-10 without removing diff cover?
  • NFB- can you determine gear ratio on 96 S-10 without removing diff cover?
    I am trying to help a friend out with a 96 s-10, 4.3 v6.We are gonna install a zexel torsen limited slip assembly in his s-10 but were not sure what ratio he has,3.08,2.73,3.23??Is there any numbers in the vin or in the glove box that denotes the ratio?Do you need to run limited slip additive with the zexel torsen setup, i think its all gear driven but want to be sure.Any help will be appreciated.
    95 trans am, golen engine 383 ,140k,6spd, procharger 12psi supercharger,racetronix fuel pump, 58mm BBK throttlebody,hooker long tubes,crane HI6-DSR ignition box,crane ps-92 ignition coil ,true duals, 60lb injectors,3.73 GM gears,csr electric water pump,edelbrock strut tower brace,descreened maf,ls1 aluminum drive shaft,centerforce clutch,accel extreme heat wires,lt4 knock sensor,autolite 104s ,hurst short throw shifter,8-01-05- 02 frt end and taillights,ws6 rims,shiny black paint job!!.
    jack it up, crawl under, put in neutral.......mark a rear tire with white chalk on one spot...mark the drive shaft on one spot.. and turn the tire and count the revolutions of the tire vs. the drive shaft ...that will give you an idea. chances are its a 4:10
      Also, see if you can find a GU-something code on the RPO code sticker.
