I have a 2000 T/A with a 6 speed and stock rear that is starting to sing. I want to go to 4.10 gears but I have to drive the car evey day and am a little worried about road manners. As it is now the car will do 45 mph at 1000 rpm in sixth gear. I just want to know if anyone can tell me how much of an rpm difference it will be with the lower gears.
Question about gears
Originally posted by LOUD2000T/AI have a 2000 T/A with a 6 speed and stock rear that is starting to sing. I want to go to 4.10 gears but I have to drive the car evey day and am a little worried about road manners. As it is now the car will do 45 mph at 1000 rpm in sixth gear. I just want to know if anyone can tell me how much of an rpm difference it will be with the lower gears.
lets put it this way, my 97 Comp T/A, 6th speed, with the lt4 hot cam and 52mm tb, and lots of other stuff... got better mileage after i put 4:10's in her... because it made 5th and 6th gear more efficient.....
Only sometimes. Usually when i slow down with traffic and i'm feelin too lazy to downshift. Anyway, can you tell me about how many rpm's your turnin at any particular speed?LOUD2000T/A
'00 Trans Am M6, K&N filter, Airbox Lid, F.A.S.T. LS-X Intake, Stainlessworks offroad y-pipe, Loudmouth catback, Pro 5.0 shifter, Hypertech programming, 17" Torque Thrust II wheels, 12.97@113; '87 Monte Carlo SS; '91 Sonoma V6 4x4.
I ahve found gas milage to be even better for me with the 4.10's
I would hadly use 6th as it was with the old gear usually only above 60
but with these 4.10's I can sit in 6th at 45 with no problem....the road manners are just fine, you will ust get higher up in gear quicker
AMF RACING: Friends don't let friends drive junk
01 black ss #0966
lou's short stick, slp lid and cold air, smooth bellow, centerforce, loudmouth, 3 in. y pipe, flowtech long tubes, BMR STB, SLP 4.10's, polished zr-1s, MSD wires, T-6 plugs, and upcoming goodies....Tee-Hee
bout 250rpm or less.. not bad at all. first gear rocks...2nd is killer! third is even more torquey..
remember, gears dont make you "faster"......they make you "quicker".
Numerically, its very simple.
4.10 / 3.42 = 1.20
For any given road speed, your RPM in a particular gear will increase by 20%. At 45mph your current 1,000RPM will increase to 1,200RPM (I'm with Ken, do NOT lug it at 1,000RPM in 6th gear). If you look at top speed in each gear (assuming stock 25.65" tire diameter), let's say at 6,000RPM:
GEAR - - 3.42 - -4.10
1st - - - 50 - - - 42
2nd - - - 75 - - - 63
3rd - - - 103 - - - 86
4th - - - 134 - - 112
5th - - - 181* - -151
6th - - - 268* - -223*
(* = theoretical, aerodynamic drag will limit speed)Fred
Originally posted by Master of StiksIf your looking for highway power and roughly the same gas mileage go with 3.73 gears...unless you have done some serious mods to it. Like these guys have said they got better gas mileage, because the gears fit their modifications better. If your car is mostly stock, 3.73.
-Stiks
I'd go 4.1097 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
