First attempt at starting this car in nearly a decade:
http://www.projectfirebird.com/files/combustion.mpg
Actually, not the first attempt, the first attempt resulted in having to reconnect a wire to the coil so I guess that was actually the second.
If you listen carefully you'll hear a tapping/popping sound, thats a broken exhaust pipe. That engine sounds sooooo good to me, and its only running on 7 cylinders there, but that problem was fixed the next day as well as the fuel problem.
Next stop... Brakes! Or transmission, not sure yet....
Quick Stats:
If you listen carefully you'll hear a tapping/popping sound, thats a broken exhaust pipe. That engine sounds sooooo good to me, and its only running on 7 cylinders there, but that problem was fixed the next day as well as the fuel problem.Next stop... Brakes! Or transmission, not sure yet....
Quick Stats:
- 1968 Pontiac Firebird Convertible
- 455 Engine
- Tri-Power intake off of a 389 GTO
- 4 Speed transmission
- Heads shaved 15 thousandths
- Cams... don't know what kind though
