OK, I got my hands on a Tech 2 Scanner and these are the numbers I came up with. I still have a problem with a rough idle and also found my water pump leaking from the weep hole right onto the optispark. Additionally, I can smell strong gas fumes coming from the rear of the car after I turn the car off. If someone can read this and tell me what is wrong I would be forever in their debt.....
Engine Speed Bouncing (650-690)
Desired Idle Speed 650 RPM
ECT 181 – 185 F
IAT 82
MAP 34 – 35 KPa
MAP 1.20 – 1.34 Volts
BARO 102 KPa
BARO 4.96 Volts
Throttle Position .66 Volts
Throttle Angle 0%
Left HO2S Bank 1 Bouncing and alternating 60 – 900
Left HO2S Bank 2 Bouncing and alternating 60 – 900
Loop Status Open (when started)Closed (after running)
Short Term FT Bank 1 125
Long Term FT Bank 1 125
Short Term FT Bank 2 125
Long Term FT Bank 2 114
Fuel Trim Cell 16
Fuel Trim Enable Yes
Spark Advance 20
MAF Sensor Bouncing 6.20 – 7.20
Knock Retard 0
KS Activity 18 Counts
Knock Sensor OK
Low Resolution Signal Bouncing 2.2 – 2.3
High Resolution Signal Yes
Injector PWM Bank 1 3.0 ms
Injector PWM Bank 2 2.8 ms
IAC Position 2 Counts
Learned IAC 10 Counts
EGR Duty Cycle 0%
System Voltage 12.8 Volts
Air Control Off
EVAP Canister Purge 0%
Injector Fault No
TC/ASR Active No
Fan CTRL PCM A10 (if eq Off
Fan Control PCM A11 Off
A/C Request No
A/C Clutch Off
A/C Status Off
A/C Refrigerant Pressure 111 Psi
A/C Refrigerant 1.26 Volts
A/C EVAP. Temperature 86
Vehicle Speed 0 MPH
Transmission Range Switch Park/Neutral
Park/Neutral Position P-N--
TCC Brake Switch Closed
TCC Solenoid Off
1-2 Sol. On
2-3 Sol. On
Trans Range A Off
Trans Range B On
Trans Range C Off
Performance Mode Switch Open
Engine or Transmission No
Engine Run Time 00:23:30
ECT 181 – 185 F
IAT 82
MAP 34 – 35 KPa
BARO 102 KPa
BARO 4.96 Volts
Throttle Angle 0%
Fuel Trim Cell 16
Spark Advance 20
Knock Retard 0
Knock Sensor OK
EGR Duty Cycle 0%
Air Control Off
Injector Fault No
TC/ASR Active No
A/C Request No
A/C Clutch Off
A/C Status Off
Vehicle Speed 0 MPH
TCC Solenoid Off
1-2 Sol. On
2-3 Sol. On
Trans Range A Off
Trans Range B On
Trans Range C Off
