Thought it was kinda a milestone, seeing as the stock motor and trans are running strong. Getting alittle low oil pressure once in a while. Think it might be a spun bearing... planning the buildup after I get engaged to the woman of my dreams!
Just Turned 123,456.7 miles!!!
Originally posted by Dan B. 96 T/AThought it was kinda a milestone, seeing as the stock motor and trans are running strong. Getting alittle low oil pressure once in a while. Think it might be a spun bearing... planning the buildup after I get engaged to the woman of my dreams!97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Good thing you included the .7!
Was that the milestone?
Will you post again saying you are even more impressed at .8? LOLTracy
I still got you beat, I turned 126,000 miles last week. and im pretty sure I have the STOCK optispark
been spittin out oil from several locations for the past 3,000. hopefully yours doesnt lol94 Firebird Formula LE3 383 - Built 4L60E w/ 3500rpm stall - Macs into SLP LM - 3.73s in stock rear - having fun with problems
Originally posted by Kevin - Blown 95 TADan - You still running my old rear end that I sold you?
Kevin... do you let guys run your rearend often?
Didn't your mother ever tell you it's not good to go around selling your rearend?Tracy
Kev,
Yeah, still have the rearend. The Ratech spacer took a thorough beating and held up well. The Richmond 3.42's went out last summer and I switched over to 4.10's with the stock crush sleeve. Since I was working at my buddy's performance shop in Wauconda I had easy access to tools and lifts, and parts at cost, so stuck with the 10 bolt for the cheap fix. The suspension is pretty much done for a road car, now just have to build the motor and trans. Then the rear.
I want to try to make Road America this fall for the MFBA event with Speed Seekers. I hope to have the car finished by then.96 T/A - Heavily Modded
87 Caprice DGCM Boxie - Stock
Gee, I can't even remember 123k. Drove mine into the shop at 236k to freshen up the engine. By the way, I did get your meaning of a milestone...... digits one thru seven.The Old Guy! '94 z-28, m-6, t-tops, go-fast red, 316k. Now with '96 engine w/ Lt-4 hot cam, roller rockers, heavy duty timing chain, and Spec stage 2 clutch.
got all y'all beat...146K with no problems...perfect running order. Weak altenator other than that...stock as a rock and running solid.
My old 3.1 bird when 265K before I sold her...so yeah, GM engines are rocks if you maintain em...
