Point-blank shotgun kills in BO7 are the kind of challenge that make you question your life choices. You’ll think you’re close enough, fire, and still get that ugly hitmarker because the falloff is savage and the game wants you basically chest-to-chest. If you’re trying to keep your sanity while you grind, it helps to treat it like a mini-mission each match, not “normal” play, and some folks even look up CoD BO7 Boosting when they’re sick of spinning their wheels. Either way, the big shift is mental: you’re not taking fair fights, you’re forcing awkward ones at kissing distance. Pick a Shotgun That Matches How You Mess Up
People argue about the “best” shotgun, but what matters is how it bails you out when you don’t get the clean first shot. If you’re confident and patient, a hard-hitter like the KSG-12 can feel unreal, because one good trigger pull ends the whole conversation. Miss, though, and you’re in trouble. If you know you panic-fire (most of us do), something faster like the M1014 is way kinder. The SPAS-12 sits in that comfy middle zone: solid, familiar, not flashy. Just don’t pretend it’s going to save you when three SMGs slide in at once. Move Like You’re Borrowing Time
Running straight at people is a free kill for them. You’ll learn that fast. What works is cutting lines of sight and showing up where they’re already stressed. Stay inside. Cut through tight rooms, stairwells, little side shops, whatever the map gives you. Slide the last stretch so their aim drifts high while you’re closing the gap. And don’t rush every door. Sometimes you wait half a beat, let them step forward, then you swing and you’re suddenly in the range the challenge actually cares about. Build for Hipfire and Getting Through the Door
Aiming down sights is usually a waste here. Your time-to-fire matters more than “perfect” aim, so a Laser Sight is huge because it tightens that spread when you’re snap-shooting from a slide. Perks should be about surviving the approach: Flak Jacket saves you from the random nade that always lands at your feet, and Ghost helps you avoid getting pre-aimed when you’re trying to flank. Scavenger is boring but real, because you burn shells like crazy when you’re forcing close fights over and over. Keep Your Head in It
Your K/D might look rough for a bit, and that’s normal. This grind rewards stubborn habits: taking the long route, resetting after a failed push, and choosing the next fight instead of chasing the last one. After a few matches you’ll start to feel the rhythm, like you can tell when someone’s about to overextend and you’re ready to punish it. If you’re still stuck and you just want the camo done without living in hallway corners all week, that’s usually when players start considering options like CoD BO7 Boosting buy as part of their plan, because the challenge is less about skill and more about repeating the same ugly setup until it finally sticks.
