Looking to dominate the endgame in Path of Exile 2? Then Bonestorm is a skill you simply cannot ignore. It feels tailor-made for shredding late-game bosses – once your gear and setup are complete, those bosses that used to give you headaches will melt like paper in front of you. The core idea behind this build is to take advantage of Bonestorm’s unmatched area damage and constant DPS, letting you clear packs in seconds while pouring massive damage into bosses. If you want to hit the ground running in a new league and stack up plenty of PoE 2 Currency, this build is definitely worth your time. Bonestorm – What’s It All About?
Put simply, Bonestorm surrounds you with a deadly storm of bone shards that automatically attacks nearby enemies. All you really have to do is move around. That makes it one of the most laid-back mapping skills out there – no need to spam-click like with other builds, just stroll through packs and watch your XP bar shoot up. In PoE 2, the visuals and impact of the skill have been seriously upgraded – shards flying everywhere, and it feels as brutal as it looks. Core Gear and Gem Links
To squeeze every drop of power from Bonestorm, your gear and gem setup need to be on point. The logic here is straightforward. Weapon Choice
1. Two-Handed Axe/Two-Handed Sword: These are the top picks. Why? They have the highest base physical damage, and Bonestorm scales hard off physical hit damage. Look for weapons with “increased physical damage” or “adds X to X physical damage” mods – they’re the backbone of your DPS.
2. Unique Weapons: Early on, certain uniques can give you a huge boost, especially ones that increase Bonestorm’s radius or add extra projectiles. Keep an eye out – the right unique can make the climb to endgame much smoother. Key Support Gems
Bonestorm’s links are just as important. A common setup would be:
1. Bonestorm – Brutality – Melee Physical Damage – Multistrike: This is your bread-and-butter 4-link. Brutality converts all your damage to pure physical, making scaling cleaner. Melee Physical Damage and Multistrike are straightforward damage boosts.
2. Advanced Links: If you’ve got a 5-link or 6-link, add “Increased Area of Effect/Concentrated Effect” (swap depending on mapping or bossing) and “Ruthless.” Ruthless hits like a truck every third attack – fantastic for boss fights. Boss Fight Tips
Clearing packs is just a matter of walking into them, but bosses need a bit more finesse. You’ll quickly realise that while Bonestorm auto-attacks, your positioning matters. Stay close so the storm keeps hitting, and use a movement skill like Dash or Leap Slam to dodge big boss abilities. Don’t get greedy – staying alive means you keep dealing damage. Also, make sure your auras are running: “Pride” boosts the physical damage enemies take, while “Determination” gives you a big armour boost to help you tank hits. Pros and Cons
The biggest thrill with this build? The sheer screen-wide AoE and lightning-fast clear speed. It’s simple to play and very beginner-friendly. But there are downsides – single-target DPS needs good gear to really shine, so early boss fights can feel underwhelming. It’s also heavily reliant on weapon physical damage, and a top-tier weapon might cost you. Finally, being melee means you need to learn boss mechanics or risk getting flattened.
All in all, Bonestorm is absolutely worth trying, especially if you love straightforward, high-impact gameplay and the satisfaction of deleting enemies instantly. It’s easy to pick up, scales into huge power, and feels great for both mapping and bossing. If you want to quickly build wealth in a new league, putting together a strong build like this is key – efficiency is everything, and with efficiency comes the ability to PoE 2 Currency buy the gear you really want.
