The Expedition Project in ARC Raiders just got a tiny shuffle, and for once a delay actually helps. Instead of kicking off right away, the first Expedition window now runs from December 17th to the 22nd, which gives everyone a bit more breathing room to tidy up their stash and maybe squeeze out a few more million in value with ARC Raiders Coins. The devs say it is all about server stability and player load, but if you are still juggling gear, it just feels like a bonus weekend to get properly set for the reset. How The Departure Actually Works
This reset is not some brutal forced wipe where you log in and everything is gone for no reason. You have to opt in through your Caravan during that 17th–22nd window. On the 22nd, anyone who signed up gets wiped together. Your level, your gear, your whole setup takes a hit, and yeah, that stings. But the trade is big. You gain permanent account upgrades that stay with you across future cycles. The standout is the +12 stash space upgrade, which is huge in an extraction game where half your brain is already managing boxes and sorting loot. On top of that, you can earn up to 5 Skill Points based on your stash value when the window closes. The math is simple: 1 million value gives 1 point, so most players are aiming for 5 million to start the next cycle with a fully juiced character. What To Loot And Where To Go
If you are chasing that 5M mark, random hoarding will not cut it. You need to focus on high-value slots. With a solid squad, you want to spend your time in Stella Montis or the Dam Battlegrounds. These spots hit hard, and the risk is real, but a Queen Core or a Bastion Cell dropping into your bag can give you 200k or more in a single slot, which adds up fast over a weekend. If you are mostly solo, it is usually smarter to work the Blue Gate during the day and go after Tempest blueprints instead of forcing messy fights. A lot of players forget this, but coins sitting in your wallet count toward your total value, so it is worth dumping duplicate gear and extra parts at the trader before the deadline instead of letting them rot in a corner of your stash. Temporary Buffs And The Next Cycle
The permanent stuff is the main attraction, but the short-term bonuses are not bad either. Leaving through the Expedition gives you cheaper repair costs and an XP boost for the next cycle, which means you bounce back to high level way quicker than someone starting cold. It changes how you play those first few days; you can take more fights, push harder routes, and not panic every time your armor gets shredded. You will notice it most if you usually grind slowly, because all the boring early missions go by much faster. It is kind of like having a built-in head start, paid for with the work you put into this cycle. Shortcuts If You Are Short On Time
Not everyone wants to grind 100 raids just to watch it all get wiped, and that is where a lot of people look for shortcuts. If you just want to jump into fights with a proper loadout and skip the long climb, you can pick up rare gear, mythics, or other high-value items and ARC Raiders Coins cheap from external sources like U4GM and use them to pump your stash value before the window closes. It is an option for players who work long hours or just cannot be bothered to farm every night but still want that big reset bonus. However you do it, by grinding or buying help, the only thing that really matters is that you are opted in by the 22nd, because once that door closes, you are stuck riding out the next cycle without those extra perks.
