another update for those interested!
Here is the latest info on the progression of the setup.
fuel pump pic 1 fuel pump pic 2
also this STREET CAR is going to have mini-tubs done
We just can't give up how quiet the Weldon A600 is.The car made it to 800rwhp with 1 pump then ran out of flow so we are adding this other one that will run on a boost switch and a manual switch.Should be enough now to hit 4 digit's
how high did you have to twist Mike's motor for the 800 ponies? WJ
Actually it was way too easy. Only 14lbs of boost and low timing.I'm expecting it will be 800-900rwhp on pump gas -street,then we will run straight C16 and push it till I had enough.Probly 20-24lbs of boost.
We will only run 75lb injectors since we want the street manners good.It did the 800hp on 60lb injectors.
We've already made 770rwhp on pump gas with a Supercharged 346,so hitting the higher #'s would be real easy with a Turbo.
All we got to do is put a Cat on Mikes car and it would pass roller Emmissions,thats how tame the setup is
Matter's if I feel lucky the day I drive Mikes car at the track.I'm sure it can hit low 10's on Nitto's and 9's on decent tires and 8's with a powerglide/suspension setup.No doubt it will be able to make the power
