My Brother needs some help.
His car started doing strange stuff. The speedometer would jump around a bit, then next time he stopped the transmission would be stuck in first gear. If he stops, shuts off the car and restarts it it shifts fine again, until it randomly decides to screw up again. He got under the car and disconnected the VSS. He cleaned the connector and put it back together. Now it is even worse, the car is not drivable. He then replaced the VSS. This has not helped. We scanned it for codes, there are
The VSS has 2 wires going to it. The sensor appears to be magnetic. What should the voltages to the wires be? Neither one of them appear to have any power with the key on.
.The VSS has 2 wires going to it. The sensor appears to be magnetic. What should the voltages to the wires be? Neither one of them appear to have any power with the key on.
