How do you "bench test" a electrical water pump while still on motor? Never had to do that it before. thanks
water pump?
 So can i check it while its still on the motor? heads are off and all coolant was drained. I was told to just hook power to it for a sec to see if it came on and shut it off quick or ill burn it up.
 current
 Well, yes..... but that doesn't tell the whole story. All you would be doing is checking to see if the motor works. The downside is that shows nothing as far as if the impeller is actually moving fluid.Originally posted by thomasSo can i check it while its still on the motor? heads are off and all coolant was drained. I was told to just hook power to it for a sec to see if it came on and shut it off quick or ill burn it up.
 and then i got this...
 "I'd get a couple of buckets, one full of water and one empty to catch the water, and a bunch of hose to reach the buckets. Put the full bucket as close to the pump as you can (like right on top of the engine), as you don't know how much suction head one of these baby's has. Make sure you have the goesin and the goesout of the pump in the right bucket, or all it'll do is blow bubbles at you."
 current
 yea pull it off, it just a couple gaskets and 10 mins, plus the motor might run but the impeller might not turn(volkswagens are known for this)2009 Honda Civic EX- the daily beater
