does anybody have any cooling updates or tricks for the 94 LT1 firebird. like any way to get fans to kick on at a reasonable temp, or anything, besides thermostat lower temp.
cooling questions
A manual fan switch. Rob B (Shoebox) has a make your own on his site http://shbox.com/1/schematics_wiring.html or you can buy them pre made http://www.slponline.com/view_product.asp?P=63011 .2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
First step would be to determine if your cooling system is in good condition.
What coolant temperatures do you see sitting in traffic, at idle, in hot weather? .....cruising at 60mph? Does the heater put out adequate heat in cold weather? Does the system need frequent coolant addition? What coolant are you running..... type? ..... mix? When is the last time the system was flushed? How was it flushed? What modifiations does the engine have?Fred
i have stock engine, its ram air, but i don't believe that makes a different. It takes forever to get warm air blowin in winter, it runs about 190-195 down highway. around 2 to 210 or a little above puting around. If you sit and let it idle for a while, it gets warm. I swear that the dang fans never come on, but i took it to a shop, the guys a friend that used to manage a shop at a pontiac dealer, he said the firebirds fans don't kick on till way to hot.
I just replaced the opti, wires and plugs, and waterpump and thermostat(180). im still kinda havin trouble getting the low coolant light to stay off. after about 20 to 25 minutes the low Coolant lights been coming on, but the coolant is pretty much full.
It seems like your operating temps are just fine. Our fans don't come on til 210 i believe it is. I put in a 160 thermostat and reprogrammed the fans to kick on at 170, and i never go over 185.
As for your warm air, it will take a little bit longer due to the fact that you have a lower degree thermostat than a stock one. If your heater takes really long though, or if the air it blows isn't that all hot, you can replace the heater core....guarantee you'll be blowin some hot air then.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
Originally posted by 95TransAmIt seems like your operating temps are just fine. Our fans don't come on til 210 i believe it is. I put in a 160 thermostat and reprogrammed the fans to kick on at 170, and i never go over 185.
Stock programming on the fans is 1st fan on (or low speed in later model years) at 226degF, 2nd fan on (or high speed) at 235degF.Fred
Originally posted by Injuneer180degF is the stock thermostat rating.
Stock programming on the fans is 1st fan on (or low speed in later model years) at 226degF, 2nd fan on (or high speed) at 235degF.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
Our LT1 engines were intentionally designed to run at hotter, more eficient temperatures that the previous Gen 1 SBC. I fail to see why people feel the need to make them run cooler. I understand that having the intake air cool helps make power because cool air holds more oxygen, but does it help to cool down the entire engine?Tracy
Originally posted by Jeff 95 Z28A manual fan switch. Rob B (Shoebox) has a make your own on his site http://shbox.com/1/schematics_wiring.html or you can buy them pre made http://www.slponline.com/view_product.asp?P=63011 .black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
Originally posted by TraceZOur LT1 engines were intentionally designed to run at hotter, more eficient temperatures that the previous Gen 1 SBC. I fail to see why people feel the need to make them run cooler. I understand that having the intake air cool helps make power because cool air holds more oxygen, but does it help to cool down the entire engine?black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
