There's usually a power antenna wire that also has to be connected. If you connected that also, then maybe the motor is dead. If not, I have no clue man.
Some people have modified the power supply to the antenna by adding a switch. Whenever you listen to CD's the antenna can stay down and if you want to listen to the radio, flip it and up goes the antenna.
Reduces the drag too
Could it be a switched ground from the factory radio that makes it go up? Try grounding the wire from the ANTENNA NOT the radio to something metal on the car with the key on, and see if it goes up. Just a thought
With my pioneer preimer deck the ant. only comes up when I put it on radio.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
Depending on what kind of radio you have, you may have hooked up the wrong wire. Some radios come with an amp turn on lead AND a power antenna lead. You have to use the right one.
Also, with the Monsoon, there may actually be two power antenna wires, and you have to jump the wire over to energize both wires or the antenna will not come up. I've seen that happen even though it is very rare.
