what was the ws6 package in 1989 on a trans am?
89 ws6 question
89 ws6 question
past rides:
1994 Z28 A4 totaledTags: None
just the WS6 package included, Level III suspention (bigger sway bars better shocks and stiffer springs, also rear springs were called cargo springs) 16x9 aluminum wheels dished(bigger offset in fron than back to clear the better suspension). A badge on the passenger side under cubby hole or letter holder that said "performance suspension" From 89 on the rear brakes were the PBR type with bigger discs on all cars, previously only on WS6. Usually they got the 9 bolt aussie posi (cone type). There are more RPO codes to look for G92 1LE(rare) and G80. If its a 305 std. WS6 it will have the 9 bolt and 3.45 gears. I think thats all. No engine mods.
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
WS6 could be had on GTA/trans am/formula See sig
There are even rumors that there are a few base line v6 firebirds with the WS6 handling package minus the wheels. But of course there is no facts to back this claim. Thought I have seen a v6 with the "performance suspension" badge on the dash. But it was wrecked a week later, so there was no need to look at it
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
true, but lucky for me I have the RPO codes still and can prove it
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
ok so this car has no rpo codes any where, drum rear brakes and 15" wheels. it only has the badge on the dash2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
you can bring the VIN to a local GM daeler and get them to retrive the RPO codes for it. It sounds like a fake to me. But there are Drum brake WS6s out there, just not to many. But the front tires would rub on the sway bars when you turn if it is a WS6. It may be a car with some of the suspension stuff added. Best thing would be to get the RPO codes. ALL WS6 cars had to have 16 inch wheels with special offset in the front to clear the heavy swaybars.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
the local gm guys couldnt do it, here is the vin 1G2FW21F3KL2485292000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
So far I have for VIN:
1- USA Built in
G- GM manufacture
2- Pontiac
F- F-body
W- Formula/Trans am
2- 2 door hatchback
1- manual belts
F- 305 V8 LB9 (TPI)
3- Check digit
K- 1989
L- Van Nuys
2- Production Number
4
8
5
2
9
I tried to get the RPO codes from a Canadian Dealer in my home town but he says that it must be a USA car as he gets an error. Just to see if he was BSing me I ganve him mine and he got them right away. He says any GM or pontiac dealership in the USA can run the vin and get the RPO codes. All they need is the last 8 numbers (year/Plant/prod. #). I trust this guy as he never led me in the wrong direction yet.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
This is my car. Some of these are even 1990 options:
AN4 : RESTRAINT, PROVISION CHILD
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8 : ORNAMENTATION, INTR, DR MAP POCKETS
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4 : MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DE4 : SUNSHADE, REMOVEABLE HATCH ROOF
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D42 : SHADE, RR COMPT SECURITY
D5T : GEAR, SPEEDO DRIVEN
D81 : SPOILER, RR, AERO WING
D86 : PAINT, TWO-TONE, DELUXE
D9E : SENSOR, VEH SPD
D98 : STRIPE, ACCENT
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING This is level III suspension
GM3 : AXLE REAR, 3.45 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
Unable to locate code IPB in our database!
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K05 : HEATER ENG, BLOCK-------------------/
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6 : TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N10 : EXHAUST SYSTEM DUAL
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM Need to find this!
PE0 : WHEEL, 16 X 8, ALUMINUM, LIGHT WEIGHT, STYLED
QLC : TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
Unable to locate code R7F in our database!
Unable to locate code R7K in our database!
TR9 : LAMP, GROUP
UA1 : BATTERY, HEAVY DUTY
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UF6 : LAMP, INTR, CONSOLE, COURTESY
UQ1 : RADIO PROVISIONS, FOR STEREO
UT1 : TONE GENERATOR, WARNING
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
U19 : SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U62 : SPEAKER SYSTEM, DUAL COAXIAL
U75 : ANTENNA, POWER, RADIO
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WS6 : PERFORMANCE PACKAGE, SPECIAL
W66 : MERCHANDISED PKG, FORMULA
Unable to locate code X06 in our database!
Unable to locate code Z31 in our database!
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
12P : WHEEL COLOR PLATINUM
13L : SECONDARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
19Q : MOLDING COLOR (BLACK)
41U : PRIMARY COLOR, EXTERIOR, BLACK
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
78A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK RED (92}
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
82B : TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
tried the dealer and no dice. have a call in to pontiac now2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
well the TA got level II suspention, not sure if it got a badge or not, but it could explain why people have the badge
I also thought that the TAs all got 16 inch rims starting in 87 or so.
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
