So, I'm putting together a possible project for the Z and have a question on which valve locks to go with. I'm getting Comp 1.6 RRs, 978 springs, 776 retainers and 4712 locators. Which lock would be best? Are there any other parts I should need? Thanks.
Valve locks
Valve locks
87 GN - its just a 6... Mods
Tags: None
I have CC 611, 11/32, 10 degree locks.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Dude, is there a reason why you're going with those springs? Just a couple thoughts...
Are you going to get a cam in the future? I've read you might need machining for them, but did you find otherwise? Also, I think they're pretty stiff, 400+ lb rating. Aren't they good up to a .600 or so lift?94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Originally posted by Craig 94 TA GTDude, is there a reason why you're going with those springs? Just a couple thoughts...
Hey Kev., which locks would be good? The 611s that Raro mentioned or would there be a better set?Steve
the best thing to do is talk to comp cams. I told them what cam I had and they rec. the springs, locks, and retainers. That's who I decided what to get. Give them a call, or check their catalog. It's in there.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by raroZ28the best thing to do is talk to comp cams. I told them what cam I had and they rec. the springs, locks, and retainers. That's who I decided what to get. Give them a call, or check their catalog. It's in there.Steve
