Okay, this problem is driving me insane. I noticed my car bogging (almost like me letting off the pedal) somewhere after the 8th mi. At first, I thought it was a limitation of the stock heads/headers not being capable of flowing that well in the upper rpms. So, I got the SLP shorties, and catco cat.
Problem didn't go away, but I trapped much higher. Definately a noticable difference, but still the same bog at the 8th to the traps. So, I got the pcmcomm logger. Everything looks perfectly normal, but every single time, it gets to 93mph at 41xx rpms in 3rd gear.... it takes out 6+ degrees of timing, and it gradually comes back to 36 degrees slightly after the trap.
I always use 93/94 octane, and occasionally a few gallons of 100 mixed in when I go to the track.
Opti was recently replaced with the MSD SC8.5mm wires, Blaster coil. Plugs are NGK TR-6's gapped at .035, but were previously NGK (55's?) stock gap.
I removed the IAT resistor also, still the same prob.
I then replaced the knock sensor with a factory gm one, and changed oxygen sensors. Still same prob again.
So, next day at the track I made another knock pass, then added 2 gallons of 110 to a third full tank, ran it for 20 mins. Same prob next run.... THEN.... Knock went away for 2 runs...
Took it out for a run about a week after that, and knock again.
So, I put in the Walbro 255... andddd same exact thing 93mph 4175rpm. arrrrggghhhh
SO, I am
on the weather to put the new NGK TR-6's, Pressure Master Header gaskets and stage8 locking bolts on. Going to inspect the wires, mabey opti again while it is down.... Need some serious help on this one, because I am running way short on money trying to solve this problem.
Where should I look next... I think it has to be a miss, fuel or spark. I doubt it is mechanical, lifters/valves/rings. Not throwing any codes for opti, but mabey cap & rotor aren't getting good contact at that exact rpm possibly. Or Digital ignition time??
This one has me baffled.... Anyone wanna take an eduacted stab at this one. Okay fingers tired from typing, sorry for the long post.
SO, I am
on the weather to put the new NGK TR-6's, Pressure Master Header gaskets and stage8 locking bolts on. Going to inspect the wires, mabey opti again while it is down.... Need some serious help on this one, because I am running way short on money trying to solve this problem.Where should I look next... I think it has to be a miss, fuel or spark. I doubt it is mechanical, lifters/valves/rings. Not throwing any codes for opti, but mabey cap & rotor aren't getting good contact at that exact rpm possibly. Or Digital ignition time??
13.410 @ 102.66 11/20/05]
I believe you've found your culprit.
So I guess it isn't so much mph, but rpm.
