Do you have a log with it at WOT? Why are you logging at only about 70+% throttle? Do you get the same results at 100% TPP?
Looks possibly like some sort of sudden mechanical noise... e.g. headers hitting the frame or steering, motor mount rattling, etc. Another possibility would be some high voltage interference that is entering the knock sensor wiring. Do you have any plug wires real close to the knock sensor or KS wire harness?
13.410 @ 102.66 11/20/05]
