Well I took a trip to Lauderdale to see my new grandson and When I fired up the formula (94) and touched the brakes the headlights popped up. OK, turned them on and got going anyway. It just rained and well maybe moisture got to something??? 150 miles later it didn't want to stay in overdrive except that the other gears seemed fine. It would be nice if I just have an electrical problem as I searched here pretty hard but found no support of that idea. If I need my tranny done in west central FL ,plze someone point me in the right direction. I read that the shifting into overdrive is partially an electrical move. Just when you start loving the car....
'94 headlights and overdrive
Well I took a trip to Lauderdale to see my new grandson and When I fired up the formula (94) and touched the brakes the headlights popped up. OK, turned them on and got going anyway. It just rained and well maybe moisture got to something??? 150 miles later it didn't want to stay in overdrive except that the other gears seemed fine. It would be nice if I just have an electrical problem as I searched here pretty hard but found no support of that idea. If I need my tranny done in west central FL ,plze someone point me in the right direction. I read that the shifting into overdrive is partially an electrical move. Just when you start loving the car....'94 formula (red)
'98 Grand Cherokee 5.9LTags: None
as far as the tranny.. it just might need some work...how many miles do you have on it?
Just approaching 100,000 but the preveous owner, a friend, had the dealer replace it with a factory replacement at about 50K. I don't run it hard I just like to test 100 every once in a while as we have a long bridge here that sorta allows it. Yeah I saw in an early postong that this is new to you (headlight thing) well If I turned the right directional it would pop up and down in sequence with the flasher and no blinking. Got it home the next day and, yeah the headlight thing quit but won't go into overdrive or stay there. Thanks for any help'94 formula (red)
I've heard of stripped headlight gears causing the lights to go up/down with the parking lights. If you had a bulb installed incorrectly it could short the parking light to the brake light and then in conjunction with a stripped headlight gear cause the light to go up and down?
I'm grasping for straws, but it is the only thing I can think of.Tracy
