smokey and the bandit
  • smokey and the bandit
    i have been watching a lot of smokey and the bandit movies well specialist 1 &2 i watch over and over and over again i enjoying it so much i'm wondering if there is movies about trans am beside smokey and the bandit?
    2001 Trans Am WS6 M6
    Smokey and the bandit three (total waste)
    Cannon Ball (David Carradine movie not to be confused with Cannon ball run)
    This lins has a pretty good list
    movie list
    1997 Trans AM WS6 vert
    1 of 463
    LT4 knock module
    strut tower brace
    SLP fan switch
    160* t/stat
    Pictures Here
      badws6 aren't you the one live at hesperia ?
        yep thats me
        1 of 463
        LT4 knock module
        strut tower brace
        SLP fan switch
        160* t/stat
        Pictures Here
          my brother lives up there i used to lived there wedgewood ct. and hot dang that is big list. thank you bro
            no problem how does your brother like living in the desert
            1 of 463
            LT4 knock module
            strut tower brace
            SLP fan switch
            160* t/stat
            Pictures Here
              when is hot is hot when is windy is cold. last time it was snow real bad i couldn't put my T/A in the garage. the driveway too slepery.and i used to lived there and work in upland long drive and freeway messed up my paint on my fender. but now i'm in upland about 5 minutes to work
                and the wind always blows ...
                1 of 463
                LT4 knock module
                strut tower brace
                SLP fan switch
                160* t/stat
                Pictures Here
                  not many ws6 over there thou well i don't think i see many ws6 in california.but yeah overthere is like not worth it zaino the car cause the next day or hour later dust just covered the car.caused wind always blow.
                  btw i might get hooper and cannonball. i believe some of folks hereremember smokey and the bandit to bad they don't make on 4th gen. they more intresting on the fast and the furious.
                    I have only seen a few WS6s and only 1 Firehawk up here My car see's only about good weather days (works out to about 5 days a year )
                    1 of 463
                    LT4 knock module
                    strut tower brace
                    SLP fan switch
                    160* t/stat
                    Pictures Here
                      A lot of West coast folks hang out here you might want to check it out ..some good get toughters and cruises
                      1 of 463
                      LT4 knock module
                      strut tower brace
                      SLP fan switch
                      160* t/stat
                      Pictures Here
                        by the time i saw ontario california it awesome i would have more f_body friends thank you bro
                          Lets not forget the TV show knight rider
                          2006 Saturn Ion Redline
                          2003 Mits. Eclipse Spyder
