i have been watching a lot of smokey and the bandit movies well specialist 1 &2 i watch over and over and over again i enjoying it so much i'm wondering if there is movies about trans am beside smokey and the bandit?
2001 Trans Am WS6 M6
SLP: short throw|short shifter|CAI|MAF|TB ByPass
Spohn: SFC|Tunnel Brace|LCA|Swaybars|LCA bracket|Shock Tower Brace|Nitto NT555 Extreme Performance|Pacesetter LT|TrueDual|1-chamber Flowmaster|DLA224/224Cam|Comp Cams 918 Springs|ported oil pump|timing chain|PRC LS6 heads|LS7 lifters|Fast Intake 90mm|NW TB 90mm|Thermostat 160|NGK TR 55|RacetronicFP|429/404 hp/tq|tuned by George Haddad motorsports
http://www.cardomain.com/memberpage/690385
Tags: None
Smokey and the bandit three (total waste)
Cannon Ball (David Carradine movie not to be confused with Cannon ball run)
This lins has a pretty good list
movie list1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
badws6 aren't you the one live at hesperia ?2001 Trans Am WS6 M6
yep thats me1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
my brother lives up there i used to lived there wedgewood ct. and hot dang that is big list. thank you bro2001 Trans Am WS6 M6
no problem how does your brother like living in the desert1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
when is hot is hot when is windy is cold. last time it was snow real bad i couldn't put my T/A in the garage. the driveway too slepery.and i used to lived there and work in upland long drive and freeway messed up my paint on my fender. but now i'm in upland about 5 minutes to work2001 Trans Am WS6 M6
and the wind always blows ...1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
not many ws6 over there thou well i don't think i see many ws6 in california.but yeah overthere is like not worth it zaino the car cause the next day or hour later dust just covered the car.caused wind always blow.
btw i might get hooper and cannonball. i believe some of folks hereremember smokey and the bandit to bad they don't make on 4th gen. they more intresting on the fast and the furious.2001 Trans Am WS6 M6
I have only seen a few WS6s and only 1 Firehawk up here My car see's only about good weather days (works out to about 5 days a year )1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
A lot of West coast folks hang out here you might want to check it out ..some good get toughters and cruises1997 Trans AM WS6 vert
1 of 463
LT4 knock module
strut tower brace
SLP fan switch
160* t/stat
Pictures Here
by the time i saw ontario california it awesome i would have more f_body friends thank you bro2001 Trans Am WS6 M6
