I am looking to get a SPEC clutch for my 95 Z but I am not sure whether to get the stage 1, 2, or 3. Money does not matter so I am looking to pick up a good clutch. Also the car is an everyday driver so I need something that suits it needs. If there is a better clutch out there for the same price range though feel free to let me know.
Good clutch to use for 95 Z28..
Zach Elwell hinse Sacius or Sac for the smart asses!
Custom CAI, Descreened MAS, Throttle body bypass, Hooker exhaust with no cat, SPEC stg 2 clutch, SPEC billet flywheel, LS1 driveshaft, Eibach sportline springs, Comp Cams 1.6 roller rockers, MSD coil, JET stg 2 chip, Short throw shifter, and plenty more to come!Tags: None
What other mods does the car have?Tracy
-throttle body bypass
-4.10 rear gears
-power programmer
-1.6 roller rockers
-cold air intake
-1le aluminum intake elbow
Just a few little things, but I plan on adding more things in the future not sure yet though.Zach Elwell hinse Sacius or Sac for the smart asses!
I wouldn't recomend a SPEC stage 2 or 3 clutch after the crap I went through with the SPEC stage 2. In all fairness other people have not had the same problems but do you want to risk it?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Speaking of clutches... what is the Centerforce II rated for HP and TQ? Will it hold my 383? Or should I opt for the Dual friction?
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
I would opt for a McLeod clutch. SPEC's are not bad but I feel that the McLeod products are better. Thunder Racing sells them.
what did you go through with your spec stage 2 clutch?Zach Elwell hinse Sacius or Sac for the smart asses!
ttt. So should I just get the SPEC stage 1 clutch then since some other people said they had trouble with the stage 2. Money is no problem though so I was going to get the stage 2. Would an SLP clutch be better to get?Zach Elwell hinse Sacius or Sac for the smart asses!
fastTa -
Sorry. I got busy last night and forgot to come back and answer your question. Here is the thread on my problems with the SPEC stage 2 clutch. http://www.f-body.com/forum/showthread.php?t=9174 To make a long story short, the clutch had about a .010 taper in thickness. It was causing a massive driveline vibration when I let the clutch out. I'd swear the rear end was bouncing off the ground. Reverse was unusable. I bought a SLP clutch disc and put it in using the SPEC pressure plate and it fixed it. I sent my clutch back to SPEC and they sent me a new stage 1 disc. Since the SLP was working fine, I wasn't going to swap discs so I can't tell you how well the stage 1 disc works. I imagine it would be fine since it is organic. The stage 2 is Kevlar. I think the stage 2 would eventually wear in but it was not worthOriginally posted by Saciuswhat did you go through with your spec stage 2 clutch?
a year for that to happen. If I had it to do all over again, I would have bought the SLP clutch, pressure plate and throwout bearing from http://www.lmperformance.com/2970/2.html .
