Hello, i am looking to purchase a 2000 and up Z28. I looked at a few. How do i tell if it is truely a Z28 SS car. I looked at one that had the hood scoop, SS badges on the sides and rear. I did not see an SS badge inside the car in the pics. It also had exausts on both sides, is this stock? It is a 2000 Z28. Can i tell from the Vin, and what is the code i should look for? Thanks
Z28 SS
Z28 SS
Tags: None
The code is NOT in the VIN. You need to look for the Y2Y code on the options sticker, not the VIN.Originally posted by ping2dayThanks for the info, i see a 2Y2 in the vin in the 9-11 spot. I will look again or ask the dealer to look for the badging for me.
If you are unsure, contact SLP and give them the VIN number. They can verify it for you. www.slponline.comTracy
one newer f-bodies...the options sticker is on the driveside door...not the glove box. I think they started putting it on the door in 97.
On the drivers door is the Service Parts Identification sticker which is probably what you refer to as the RPO decal. Also there is an SLP sticker saying something to the affect that they have modified the car (when they turn it into an SS). The sticker on the passenger side shows all the extra cost options that are installed on the car (if any) by SLP.Originally posted by 4THGEN ZYeah but isn't your GM RPO code decal on the drivers?
So the real tipoff....at least on 2002's......should be the two SLP stickers. If you see those, then you most likely have found a true SS.Dave S
2000 Black Camaro SS
I have an 01 ss # 967 I am selling if you are interested send me a message if so, car is phenomenal
AMF RACING: Friends don't let friends drive junk
01 black ss #0966
lou's short stick, slp lid and cold air, smooth bellow, centerforce, loudmouth, 3 in. y pipe, flowtech long tubes, BMR STB, SLP 4.10's, polished zr-1s, MSD wires, T-6 plugs, and upcoming goodies....Tee-Hee
kill the caps lock key. typing in all caps is against the rules, broh.Originally posted by ping2dayI SENT SLP THE VIN. THE DEALER SAID HE FOUND IT ON THE DRIVERS SIDE DOOR, MAYBE IT IS A BOGUS STICKER. WE WILL SEE. THANKS FOR THE HELP.
the slp sticker is on the pass. door. its a dot compliance decal. its required. in earlier models there was also one under the hood.
and to insure its an ss.......you can always find a firehawk, then go to the track........if its an ss......it will lose............
hahahahahahahaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Originally posted by wolfmanthe slp sticker is on the pass. door. its a dot compliance decal. its required. in earlier models there was also one under the hood.
Next you are going to tell us that Envoys wil beat SS's too.......
Dave S
