hello... i was wondering if anyone knew of anything about camaros with firehawk engines. my car is a 94 z28 and it will spin tires going into second fairly easily. i have driven other z28s that were newer that didnt do that. the car seems to be stock but im not sure. i bought the car with a blown head gasket and the guy that i had take it apart for me told me that the engine code matched up with that of a firehawk. for a 94 its pretty fast. the other day i raced a 97 trans am 6 spd with exaust and gears... i beat him by atleast a car length and a half in a race that was close to 1/4 mile in length and i cant quite beat a new ss but i can hang fairly well. i am not so sure so i was wondering if anyone had heard of a car like mine[/FONT]
Firehawk Engine?
who ever you talked to was on drugs. there is no such thing as a Firehawk engine.Originally posted by kaytonhello... i was wondering if anyone knew of anything about camaros with firehawk engines. my car is a 94 z28 and it will spin tires going into second fairly easily. i have driven other z28s that were newer that didnt do that. the car seems to be stock but im not sure. i bought the car with a blown head gasket and the guy that i had take it apart for me told me that the engine code matched up with that of a firehawk. for a 94 its pretty fast. the other day i raced a 97 trans am 6 spd with exaust and gears... i beat him by atleast a car length and a half in a race that was close to 1/4 mile in length and i cant quite beat a new ss but i can hang fairly well. i am not so sure so i was wondering if anyone had heard of a car like mine[/FONT]
All f bodies with a v8 got the same motor, the LT-1. The firehawks recieved an upgrade with slp engineerings exhaust system and a ram air unit, other than that, ther is no diffence in the LT-1 that came in any other f body for that particular model year.
some Lt-1's run stronger that others. Our Firehawk has one of those "1 in 500".. its chirps third with an A4 and bolt ons. My Comp TA didnt, but I built it up so it would run with an LS-1. You may have been lucky and just got a strong lt-1 from the factory..but.......
firehawk engine................ tell that guy to do his homework.......hahaahahhahaahaha
Wild guess. Could it be a LT4? Those came in hawks and ss's. But only a 100 or so i think.1996 Trans Am:T-tops,graphite leather,16" chrome T/A rims, Nitto's, Descreened MAF, Morosso CAI, hypertech, flowtech cut out, 1LE elbow, Silver BMR tubular SFC's, 160 thermo, limo tint, harwood ws6 hood, !side molding, Stage 2 trans.
100 SS's and 29 Firehawks.Originally posted by purepwrtaWild guess. Could it be a LT4? Those came in hawks and ss's. But only a 100 or so i think.
97's.
the guy that told him that should have known by the red intake and red heads... not the engine serial number. and i would think the owner would see the motors diff from his buddies in color too.........
red heads?Originally posted by wolfman100 SS's and 29 Firehawks.
97's.
i wonder if that also happen to LS1 one LS1 engine is stronger than other and how can you tell ?Originally posted by wolfmanwho ever you talked to was on drugs. there is no such thing as a Firehawk engine.
firehawk engine................ tell that guy to do his homework.......hahaahahhahaahaha2001 Trans Am WS6 M6
It can happen to any motor. Motors always have a set of tolerances. The "looser" motor is likely to win. There are a few other small factors such as a well balanced engine vs a lemon underpowered motor.Originally posted by 1sickbirdi wonder if that also happen to LS1 one LS1 engine is stronger than other and how can you tell ?
For some examples of the variances on the LS1, read this thread:
http://web.camaross.com/forums/showthread.php?t=320865
I've seen underperforming LS1s run 100 in the traps, all the way to "factory freaks" run 110 in stock form.
To truly know how good your motor is, the only way is to dyno it, or even take it to the strip.94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
yup. thats right. the dyno numbers all over the board for both lt-1's and ls-1's...ive been exsposed to hundreds over the years... its amazing... up to 30rwhp...some cases more!Originally posted by Craig 94 TA GTIt can happen to any motor. Motors always have a set of tolerances. The "looser" motor is likely to win. There are a few other small factors such as a well balanced engine vs a lemon underpowered motor.
heck..joe thought he had a v6...............................
heee heee (dukin)
z28_xxx
LT4 engine in 1994? BUHAHAHAHAH
z28_xxx
ALL ENGINE CODES MATCH THAT OF A FIREHAWK
ALL LT1 engine codes are 'S' on the VIN
Ummm, the LT1 is VIN code P, not S. Where did you get that??Originally posted by z28_xxxALL LT1 engine codes are 'S' on the VINSteve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
Dude, you're cruel lolOriginally posted by alensteinMine says 'P'.
BUAHAHAHAHAHA
...newbie
j/k
Steve
Mods
Mods
Mods
mine dont say nuttin......Originally posted by alensteinMine says 'P'.
BUAHAHAHAHAHA
...newbie
it cant tawk..........
