I have 245/40/17 KD's all around currently. I cant hook for my life. The gaps are uge between the tires and fenderwells. I wanted to drop the car as well. I wanted to know if it would be a good idea to just get 2 new rear tires. Something bigger like 285's. I was thinking the f1-gs-d3. would that be a smart idea to put 2 of those 285s in the back and keep my 245 KD's up front. I really dont have the money to buy tires and they are relativly new as well. thanks
rear tires question
With 245/40-17's all the way around, did you correct the tire size in the PCM, so the speedo and odometer would not be "off"? If you didn't, your speedo has been reading 3.8% high, and your odometer has been adding 1038 miles for every 1,000 miles you actually drove. That assumes your car left the factory with 245/50-16's. If you had the "base" 235/55-16's, its even worse. The 24.7" diameter is contributing an extra 1/2" of daylight between the tires and the fenders.Originally posted by lt14mlaI have 245/40/17 KD's all around currently....Fred
no i havent corrected it because im going to be swapping out a rear end as well in the next week or so. the gears will be 3.42 instead of the current 2.73's. I figure thats the best time to change the PCM. But i was thinking of getting some 285 or something in the back first and leaving the 245's up front and then changing the pcm. thoughts?-Lou -
1997 30th Anniversary Firebird Formula
